hitrace Posted April 18, 2014 Report Share Posted April 18, 2014 No sound from headphones? I have replaced the battery but now there is no sound from the headphones the display shows it is working and the volume is turn up I have tried other headphones that I know are working but still no sound. The unit wlll play with sonic stage so there are files wich are ok any suggestions will be appreciated Hitrace Quote Link to comment Share on other sites More sharing options...
0 sfbp Posted April 18, 2014 Report Share Posted April 18, 2014 Was it working before? Or did you acquire it like this?You may want to get into service mode and check a few things. Not sure how you load updated firmware.Maybe you made an error when replacing the battery? Or maybe it needs some sort of calibration with a new battery installed.Does the battery charge fully? Quote Link to comment Share on other sites More sharing options...
0 hitrace Posted April 18, 2014 Author Report Share Posted April 18, 2014 It did work before replacing the battery. Battery replaced as described in the sony manual ,there is no mention of having to reset anything. Have check and reset machine as in the sony manual Quote Link to comment Share on other sites More sharing options...
0 sfbp Posted April 18, 2014 Report Share Posted April 18, 2014 I think a service mode reset is not the same as the "user" reset. But it may need firmware. So research very carefully first. Quote Link to comment Share on other sites More sharing options...
0 Stuge Posted May 15, 2014 Report Share Posted May 15, 2014 The unit wlll play with sonic stage so there are files wich are ok Hitrace what do you mean by this ? Quote Link to comment Share on other sites More sharing options...
hitrace
Hitrace
4 answers to this question
