peter stagg
hi all
i have windows 10 and beatjam sees my minidisk sharp im-dr410e as net md
it refuses to convert to open mg from mp3 saying "could not convert because beatjam does not support the conversion of this file format"
it is an mp3 file
i have oracle virtualbox with win xp running and it converts the same file no problem
but when i try to add the converted file to beatjam host win 10 it says "beatjam found openmg format music files that cannot be used on this pc"
i cannot get the net md drivers to install on the vm win xp
device manager install driver says
"there was a problem installing the hardware net md
an error occured during the instalation of the device
driver is not intended for this platform"
the same drivers worked on win 10 hence i want to use beatjam on windows 10
also after installing sonicstage 4.3 3.4 and 2.3 after running it is crashes and my computer goes all laggy and the performance goes down alot but in taskmanager its all fine
is there any thing i can do to get the drivers to work on the vm win xp
The simplest method is undoubtedly "don't use Beatjam".
We don't know much about it here. However, you don't even need an xp VM if you use SonicStage. You'll need our version, and (probably) the 64-bit driver for NetMD.
Kind regards
to sdbp thanks for the reply and help with this ive been trying to get this to work for ages
i have sonic stage 2.3 3.4 and 4.3 when i open them they all make my computer very slow and they wont let me add songs to the libary
i can see my minidisc recorder it shows up as net md
is there a different sonicstage that your refering to if so can you post a link and tell me if ther is special launch requirements
my specs
ryzen 5 2600x
corsair lpx 16gb 3200mhz
2x8gb
msi b450 motar max
amd r9 390x
windows 10 pro
128gb nvme
2x2tb hdds
1 sandisk ssd
The one that's in our downloads section.
This stuff works, provided you have the right driver.
I have no clue why slow but SS does have some strange code so I would turn off DEP protection as well as all realtime Windows Defender functionality. Honest!
