gsf Posted January 21, 2007 Report Share Posted January 21, 2007 Hi I manually formated my NW-E407 and deleted all the files on it (OMGADUIO is still there, but i think its missing a few things). When ever I turn it on it says Data Access and then Format Error. Also when I connest to sonic stage 3.1 I am able to get into the device/media and initialize but it still doen't work ( the reset button also gives me the same message. Can anyone help? or send the original files for the NW-E407 could you please send it to me. thx Link to comment Share on other sites More sharing options...
aznbro85 Posted January 21, 2007 Report Share Posted January 21, 2007 (edited) Dear gsf, Hello, and welcome to ATRACLife Colloquium.. I hope you enjoy your stay here. Have you tried to reformat through the player? To do this, open up the menu, go to "advanced menu" then select "Format" Hope this solves your problem! Edited January 21, 2007 by aznbro85 Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 21, 2007 Report Share Posted January 21, 2007 Welocome to AtracLife!Never format your player manually .Always Format it from the playe itself (via advanced menu )First you will have to format it ,then you will gain have to tranfer songs via SonicStage .Only then your player will play songs.I will suggest you to upgrade your old version to new Version of SonicStage i.e SonicStage4.2 ,but prior to that back-up your audio files using SonicStage back up tool. Link to comment Share on other sites More sharing options...
gsf Posted January 21, 2007 Author Report Share Posted January 21, 2007 Guys - Thanks a lot, problem solved after formatting via advanced menu. Leson learned! Cheers. GSF Link to comment Share on other sites More sharing options...
jackpott Posted February 17, 2007 Report Share Posted February 17, 2007 hey guys i lost my nw-e407 cd i need mp3 file manager ver:1.0 so i want to upgrade but i cant pls help me Link to comment Share on other sites More sharing options...
ender325_ Posted February 17, 2007 Report Share Posted February 17, 2007 hey guys i lost my nw-e407 cd i need mp3 file manager ver:1.0 so i want to upgrade but i cant pls help mehttp://esupport.sony.com/US/perl/swu-downl...36&os_id=99^ There's the link to the MP3 File Manager 1.2 for the NW-E407. Be sure to bookmark that page for future reference. Link to comment Share on other sites More sharing options...
luked420 Posted November 1, 2013 Report Share Posted November 1, 2013 necro update - this worked for me as well, Link to comment Share on other sites More sharing options...
