Guest Anonymous Posted June 10, 2003 Report Share Posted June 10, 2003 okay, I solved that problem by cutting down the Temp file to just: Docume~1 Don't know why that worked. Now the Image is mounting properly and SimplerMD is recording for me, but the track names aren't carrying over. IT'S THE TRACK NAMES I WANT!! argh.... help? Quote Link to comment Share on other sites More sharing options...
Clint_Mers Posted July 6, 2003 Report Share Posted July 6, 2003 okay, I solved that problem by cutting down the Temp file to just: Docume~1 Don't know why that worked. Now the Image is mounting properly and SimplerMD is recording for me, but the track names aren't carrying over. IT'S THE TRACK NAMES I WANT!! argh.... help?Is it doing anything with the names? Is the option checked to write the track names? Note that you have to let SimplerMD erase the disc to start or it won't try to write names. Also note that tracks are named by the filename, not MP3 tags. If all is working properly, the last step of the process should be to open SimpleBurner and rename all the tracks. This happens after all burning is done. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 11, 2003 Report Share Posted July 11, 2003 Oh creator - good job on this automation proggie! I suffer from the same Nero error 1101 ailment that other posters have encountered - other than that it works fine! Some send keys, like the burn button never have for me, but I click to contine and wha-la - it's all good. Question: what software did you use to write the app? Second, you used SENDKEYS to automate? Is there an API or reference I can use for them? I use VB6 an d make small apps to automate redundant stuff at work and am considering learning Delphi. Answer if you like please. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 5, 2003 Report Share Posted October 5, 2003 MZ-N10-THIS IS A SHIT UNIT- i'm going to punch the sale person :evil: http://forums.minidisc.org/viewtopic.php?t=2897 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 19, 2003 Report Share Posted October 19, 2003 ok i get the error invalid file extension specified. (error 1000) help please anyone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 20, 2003 Report Share Posted October 20, 2003 Clint Mers, Thank you for making this program. It works absolutely great!!! I am on my second MD unit now, a Sony MZ-N10, and with your program I will get an incredible amount of use out of it. It's great to select all the songs you want, click 'Start', and go do something else, instead of sitting there at the computer. My old MZ-R500 still plays back, so I could take a disc with me on a jog and leave the N10 at home recording. The only 'problem' I'm having is with titling. It seems there is a limit of 12 characters. Other than that, everything works great. I have the following software: Windows 2000 Professional Nero Burning Rom v5.5.10.54 Nero ImageDrive v2.23 Sony SonicStage v1.0 Sony NetMD Simple Burner v1.0 Sony UI Library Again, thank you for you services. Manuel Feliz US Air Force Quote Link to comment Share on other sites More sharing options...
Hemlock Posted November 4, 2003 Report Share Posted November 4, 2003 Will it keep the bitrate of the original MP3's or does it change them to 64kps? If I had 96Kbps MP3's and transferred them at 128 Kbps would they effectively stay at 96kbps size (and quality). 64 is too low and 128 it too high for me. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 14, 2003 Report Share Posted December 14, 2003 well it seems like it doesn't work under windows 2003 server, but I think it's because sony's shitty software. the simpleburner simply crushes and quits to windows after pressing rec. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 15, 2003 Report Share Posted December 15, 2003 ok i get the error invalid file extension specified. (error 1000) help please anyoneI get this error as well, after I hit the start button. After OKing the error box, the nero burning software fires up but just sits there with the empty NRA file open. All paths etc are OK Anyone got any clues? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 17, 2003 Report Share Posted December 17, 2003 well i got simpler md and tried it.. but nothing.. it hangs when loading..the files into nero.. it seems maybe its uncompatible with nero6... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 23, 2003 Report Share Posted December 23, 2003 I get this error as well, after I hit the start button. After OKing the error box, the nero burning software fires up but just sits there with the empty NRA file open. All paths etc are OK Anyone got any clues?Just a bump on this thread because I'm experiencing the same error as well: "Invalid file extension specified. (error 1000)". I'm running Simple Burner 1.0.03.09100, SimplerMD 2003.04.15, and Nero 6.0.0.23 with Nero ImageDrive 2.23 all on Windows XP. Any ideas anyone? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 23, 2003 Report Share Posted December 23, 2003 Just a bump on this thread because I'm experiencing the same error as well: "Invalid file extension specified. (error 1000)". I'm running Simple Burner 1.0.03.09100, SimplerMD 2003.04.15, and Nero 6.0.0.23 with Nero ImageDrive 2.23 all on Windows XP. Any ideas anyone?Me too! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 24, 2003 Report Share Posted December 24, 2003 After I spent all night downloading a bunch of software to make this happen, I stumbled upon this macro-derived genius software and was thrilled about the prospects.... until I got this error message also. Has anyone figured out the source of this error and gotten past it? There are obviously people who have successfully used the program.... where to from here? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 26, 2003 Report Share Posted December 26, 2003 Seems as though that error 1000 started popping up on people after the release of Nero 6. Are all you guys with that error running 6? Does the author still pop in to these forums? Has support for Nero 6 Plantium been introduced? -Neo Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 26, 2003 Report Share Posted December 26, 2003 From these reports the problems really seems to root on the Nero6 software... Let's see what happens if I install Nero5 too :roll: Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 16, 2004 Report Share Posted January 16, 2004 sorry to spoil the party but i was wonderin if there will be a versoin of simpler md that you can upload from your mds with? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 17, 2004 Report Share Posted January 17, 2004 Ok, there seems to be issues with SimplerMD and Simple Burner 1.1.0.11141, which is the latest version. Everything runs fine until the stage where Simple Burner is going to write the files to the MD. It just freezes at the Recording stage and nothing happens. I'm wondering if there is something different about this version that is causing things to screw up. Any help would be appreciated. Sony MZ-N910 Sonic Stage 1.1 Simple Burner 1.1 Nero 5.5.10.42 ImageDriver 2.23 Windows XP SP1 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 17, 2004 Report Share Posted January 17, 2004 Sorry, SonicStage is version 1.5 Quote Link to comment Share on other sites More sharing options...
lforman Posted April 21, 2004 Report Share Posted April 21, 2004 Hi, I'm a newbie to the NetMD process. I have a sharp NetMD don't want to use Soundjam. Do I need to install SonicStage or any other software other than my drivers, simpleburner and nero? thanks, lisa Quote Link to comment Share on other sites More sharing options...
Danorah Posted September 8, 2004 Report Share Posted September 8, 2004 I just found out how to use ImageDrive to create my MDs and it works perfectly! I wanted to try SimplerMD but unfortunatly it doesn't work at all... I followed all the instructions and it seems to work well at the beginning, but once Nero has started nothing happens anymore... Do you think it is because I have a french version of Nero ? (Yes I am French, so sorry if I made a few mistakes...) Could you help me please ? Quote Link to comment Share on other sites More sharing options...
aeriyn Posted September 9, 2004 Report Share Posted September 9, 2004 Don't dig up old threads. Not a good way to start off here. :whatever: Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 9, 2004 Report Share Posted September 9, 2004 Aeriyn, this is a stickied thread. :happy: Unfortunately, I do not believe this process works well anymore - so I will unsticky it for now. Please try Sonicstage 2 or Simple Burner 2, Danorah. Quote Link to comment Share on other sites More sharing options...
