Trippin Posted January 9, 2004 Report Share Posted January 9, 2004 hi, I have a problem with mu Sony 505 with some sort of protection. Not sure how to overcome the problem but I cannot write onto my discs and I can't erase them eather. It seems to be the problem with check-in check-out thing but I'm not sure how it works. Is there a way to force discs to erase or use different burning software to overcome this problem? Seems useless to be able to burn songs 2-3 times and then you can throw away the disc. I can't even erase directly through the mini-disc player without using the PC software. What's the trick? Thanks Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted January 9, 2004 Report Share Posted January 9, 2004 use SimpleBurner when you transfer files across...this gets rid of practically all your problems of being restricted to use a PC to do a disc erase etc...that and i don't think there is a check out limit on it (i havn't run into any for the time being)...use the Nero + SimpleBurner trick that has been outlined in the forums and you should be good to go... Quote Link to comment Share on other sites More sharing options...
KLank Posted January 9, 2004 Report Share Posted January 9, 2004 You can also use RealOne to get around the copy limits too. Quote Link to comment Share on other sites More sharing options...
Trippin Posted January 11, 2004 Author Report Share Posted January 11, 2004 Thanks for the reply , but with simple burner I can only copy cd-s can't copy my mp3 files , or is there another version? What do u mean use Nero burner for this ? Sorry I can't say I understand how to use RealPlayer in this purpose ... I must be really uninformed can you be more specific as how to do this? I tried copying the cd with simple burner but it still wont let me erase the files reports some sort of "internal error" I've tried few mini discs but the same problem . CHeers Quote Link to comment Share on other sites More sharing options...
Bazirker Posted January 13, 2004 Report Share Posted January 13, 2004 There's a trick to use Simple Burner to transfer mp3's and other audio files on your computer to minidisc. Take a look here: http://forums.minidisc.org/viewtopic.php?t=880 And here's a program that helps simplify the process: http://forums.minidisc.org/viewtopic.php?t=1815 Quote Link to comment Share on other sites More sharing options...
