sonic stage keeps forgeting my library
onlykaria
why is it that every time is start sonic stage 2.0 (the officail sony release) i keep having to re import my library this is very time consuming and annoying.
i hate it, and want it to just remember my music the way real player does.
Did you have this problem with iceeedtea's build?
i did everytime i tried to copy a song to MD it would say that i have run out of check outs.
but then i got an Atrac/Mp3 CD which uses the same Sonic Stage Software, but this is giveing me a problem too.
1- when i exit i have re import the library
2- when try to copy to MD it says i am out of check outs (even on songs i just ripped from CD)
3- when i try instead to make an atrac CD, it says that Sonic stage doesnt reconize MP3. LOL i think i am just oing to give up and get a good old fashioned basic CD player.
Well..I would at least try uninstalling everything first [do it the way it's prescribed in the NetMD faq, registry deletions and all] and try a complete reinstallation. I bet if I was at your 'pad I could get it working after a little while..probably just some little discrepancy.
i've gone it twice, but i guess it cant hurt is i will try that ...again... heck i am so desperate to get this working, i might call sony's evil tech support.
maybe i will play the lotto win it, and get an new computer as to not have to deal with this...
but is there anything else that might help anything at all?
