MZ-NH1 MZ-NH900 CONECTED TO AN AMPLIFIER
arodriel7
I want to buy MZ-NH1 or MZ-NH900 to record and also to play music connected to a home theater system (amplifier ONKYO and speakers Whaferdale of medium slightly high quality)
1. How they sound when connected to an amplifier to play in a stereo system?
2. Any problem with de digital amplifier of the minidisk?
3. Can I use unsure.gif the remote when the line out is connected to my amplifier?
4. Suggestions, tips, problems about playing connected to it?
Thank you very much :smile:
I have the NH1
a) It sounds fine when connected to my Technics amp
cool.gif I have no problems with the digital amp, however thats not to say you wont have any. I believe that if the amp you connect to is unterminated then you will have problems.
c) No you cant use the remote while connected to an amp. Connecting the remote puts the unit into headphone output mode & you cannot select line out. Also on the NH1, all the functions are done from the remote so its a pain to use for line out (but not impossible)
d) Nothing to add. Dont have any tips or problems.
