kalo Posted September 30, 2004 Report Share Posted September 30, 2004 This question may sound stupid. can I use the 800's radio powered remote for the 900 or is there something else in the 800 that makes the radio work? Quote Link to comment Share on other sites More sharing options...
Davew Posted September 30, 2004 Report Share Posted September 30, 2004 If you take a look at the 800's remote plug, you can see it has 6 contacts on it, two of them are above the main section and only the 800 has the notches in remote jack to accomodate the plug. Hope that I have explained that clearly :smile: Dave Quote Link to comment Share on other sites More sharing options...
Christopher Posted September 30, 2004 Report Share Posted September 30, 2004 Unfortunately you cannot use that radio remote with the NH900 or any model except the NH800. It may work with previous radio-type units, however.. Quote Link to comment Share on other sites More sharing options...
