Recharge Standard Rechargeable AA Batteries with nh900
kalo
I don't have a 900, but looking at the user manual pdf it seems like you can't charge an external battery using it. It looks like you can't plug the AC adapter into the device when you are using the external battery, is that right kalo, or am I wrong?
If you go to http://www.minidisc.org/part_Sony_MZ-NH900.html
and look at the Battery life section at the bottom of the page, in the
'Recharge' it only has a time specified for the NH-10WM gumstick.
Which also makes me think that you can't recharge the external AA.
Dave
