Sonicstage problem...... Gaps.
mission22
I have a problem and cant seem to see a way around it. When a mixed CD (ie a dance music cd with non stop music) is copied and transfered to my player it puts gaps between the tracks. This is very frustrating as the flow of the music on the original cd is seemless not broken up half way through the mix.
Does anyone know how to remove these gaps between tracks and make it play as the orginal?
Help...
SonicStage cannot play gapless. However, all MD-recorder can play gapless standalone. Mostly, after transfer and playing standalone, you should get a gapless recording. But, some CD-drives do introduce gaps during ripping. In that case, connect your MD recorder to a CD-player and record realtime. That one will be definitely gapless. (Not possible with NetMD downloaders: NF520/N420/NH600D)
