StarCapt Posted October 16, 2004 Report Share Posted October 16, 2004 I have had a lot of help in this forum and need more. SonicStage 2.0 came with the Sony MZ-NH900 when I ordered it. I can now successfully use the "real-time" method of uploading Hi-MD files to my computer in .wav form by using methods described here that employ Total Recorder. But I can't use the now-popular HiMDRenderer program since SonicStage 2.2 will not successfully download to my computer. I always get the message that some file is missing. I followed a previous thread of someone who had the same problem, then when he said he solved it, he said he didn't know what he did right. Can anyone solve this problem for me? Thanks in advance for helpful replies. Quote Link to comment Share on other sites More sharing options...
pethunia Posted October 16, 2004 Report Share Posted October 16, 2004 :wacky: You don't want to hear this - but (nice - for a change!) my download of SS 2.2 went fine. Just some speculation: Were all other applications closed when downloading? Is there some firewall-setting that might be set to 'disabled', while installing SS ? Find another download-site to get SS 2.2 from? good luck Albin Quote Link to comment Share on other sites More sharing options...
