To complement the subjective listening tests done on the new bit rates of ATRAC3plus --> notably 320kbps (in this thread), I have conducted a frequency analysis for your technical curiosity.
*Thanks to greenmachine for the concise Adobe Audition guide.
Original file: Nina Simone's I Loves Porgy.
Green: original uncompressed file
Red: ATRAC3plus, 320kbps
Blue: ATRAC3plus, 256kbps
Yellow: ATRAC3plus, 192kbps
As greenmachine illustrated in his earlier frequency analysis, there are no significant difference between ATRAC3plus 320kbps and 256kbps. They are almost identical in terms of quality as shown in the graph above. However, one can easily discern ATRAC3plus, 192kbps from 320kbps and 256kbps. In addition, it is important to note that the frequency analysis is not the absolute answer to sound quality as there are other variables - notably artifacts
Ishiyoshi
Discuss accordingly.
37 answers to this question
