help: special cable needed
Truth_Seeker1
Hey all,
I have an MZ-NH1 and really need one of two things:
A. for the recorder to be able to charge itself through the USB
connection, or:
B. a cable that, on one end, plugs into the recorder, and on the other end, has a USB connector (for transferring recordings) and a power plug (for recharging). This is preferred.
Any ideas? Any help would be greatly appreciated.
Drew
None of the HiMD units can recharge batteries while being used, whether via USB or standalone.
In SonyThink, the cable you're asking for wouldn't really have a purpose, since they can't think in terms of the convenience a single cable would offer for those who, say, travel - and find carting the cradle et al around to be a pain.
If I'm not mistaken, the connector on the NH1 is completely non-standard and you won't find anyone other than Sony who could do anything with it.
But I might be mistaken. I don't have one, myself.
what he wants might not be hard to do.
the bizzare USB cable that Sony uses has extra pins used for the charging of the unit. if someone could mate up a NH1 USB cable with a 6vDCin AC adapter...
... I don't think it'd be hard to do, if you could identify the extra pins. :happy:
if it's any help, i tossed around something very similar like this for my N10.. the connector has like, a dozen pins of which i managed to figure out what they were.
The battery box also has the same connector, so i slid back the plasticky sheath and read out the voltages.. there was a 1.1v connector and a 6v connector from memory along with the four USB pins (gnd, +5v, data1, data2) If you plugged it into the PC via the USB cable and crossed the 5v and 6v pins (thus sorta powering it..) you'd get the red charging light and battery charging indicator. I know i know, its somewhat crazy, but it seemed to work.. I *was* going to make a permanent mod and do some other things, but i got an NH900 instead.
The point of this is that if it was possible on the N10, i'm sure its in the same vein as the NH1... interestingly enough, this was one of the reasons i instead went for the NH900 as its part of my mobile rig. Cradles arent mobile.
