Usb cable
Unless you have a PC to use with an MD then your options are going to be VERY limited.
Hi-MD is capable of transfering audio from MD - PC when working in Hi-MD mode and you can now use the Wave converter tool to convert the DRM'd file into a wav file. However you need to use SonicStage to copy the music off the disc & this is PC only software.
The only way to use an MD with a Mac is the old way of using an audio cable to link the line out on the MD into the Line in on the Mac.
so,  with any minidisc with usb port I will be able to transfer audio files to a PC and then convert them to wav format..right?
Do you lose sound quality in the transformation?
Is the transform software shareware?
Can you recomend the cheapest sony minidisc with usb port and mic in?
thanks..
Yes you can transfer audio files to the PC with any Sony Hi-MD unit. Note Hi-MD, not NetMD. The transfer software (SonicStage) is free and available from www.connect.com.
No, the transfer is digital so there's no loss. However, SonicStage has the nasty habit of destroying tracks to be transferred to the PC, incidentally rendering them lost forever. Be careful before you transfer, and make backups if possible.
The cheapest Hi-MD model with a Mic In would be the MZ-NH700. It sells for around 200USD, from what I've seen, although I don't think that the unit itself is marketed in the US...
