Quick questions about SS 2...
Gyro
First of all, I'd like to say that the moderator's FAQ with getting this program to work is amazing. For a while, I couldnt get it to work, it (1.5)would freeze up, etc. So i got the new version...followed the instructions, and voila! it works. OK, heres the questions:
1) Where does the CD information show up when I insert a Cd?
2) Where do I make playlists? (is it the create/edit my compilation album?)
3) If so, is there a way to get the library to stay where it is when i drag it over to the compilation? Its really annoying when I have to start up at the top every single time.
Thanks for helping the newbie.
