darkraid3r Posted November 6, 2004 Report Share Posted November 6, 2004 OK first i am going start by saying i am new to the MD I bought a used Sony MD MZ-R70 problem i am having is i insert a new blank md and start to record it all goes well then when it is done it said TOC EDit i do not touch it till it is done then it said end ok then i turn off my md and press play but it keeps telling me blank disk. what am i doing wrong? please help Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted November 6, 2004 Report Share Posted November 6, 2004 Return the unit, it is faulty. It seems like the original owner sold it because the magnetic record head cable is broken. Minidiscs rely on a magnetic head on the top of the disc to record the changes into a recordable disc (along with the laser to heat the disc to allow it). If the cable to the head is broken then the magnet will not be energised and therfore it will not record, this also has the result of blanking any disc you put into the machine. On a different note, the MD you have should still function as a player only unit. Quote Link to comment Share on other sites More sharing options...
