Hi-MD Renderer problem
Nid
Hi, i am not sure whether this is the right place to post a problem but here goes,
Well my mate recorded soemthing onto his hi-md and gave it to me via a USB Flash drive i use the converter program but i get the proble "failed to dec splitier" Coudl anyone tell me what is wrong and how to fix it?
Thanks,
Nid
Yes. HIMDRenderer requires that you install Sonicstage 2.1 or later.
HIMDRenderer uses DirectShow and the DirectShow modules that are installed when you install SonicStage 2.1.
The error "failed to create dec splitier." (badly spelt, sorry) means that my program failed to create the "OMG Decoder Spliiter" Sony Directshow module.
Also, just to add a small note, the .oma file need to be playable in SonicStage for them to work with my program.
