giuspy82 Posted November 18, 2004 Report Share Posted November 18, 2004 hi, i'd like to have some advices from you: i must direct a short movie, so i want to record the audio in a minidisc recorder with an external microphne , and then i want to transfer all from the minidisc recorder to my power mac.I know there are some models that not permit to do these..i want cd audio (very good) and i want to spend a very low price...can you give me some information??I need urgent help from you!!thanks so much bye! joseph Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted November 18, 2004 Report Share Posted November 18, 2004 MD and HiMD are not supported on Mac. You could try using Virtual PC but the one reported attempt we've had here was that it was unbearably slow. MD itself does not support digital upload - with the exception of home decks, which have optical outputs. Also: MD and HiMD as yet have no SMPTE support, meaning that synchronisation to your video tracks must be done by eyeballing things in your editor - not an uncommon situation for low-budget productions, but at the very least, be warned not to expect SMPTE support. As long as you don't mind doing analogue transfers [using standard audio cabling and a sound card with line-in] you can use any MD or HiMD with your Mac. HiMD supports linear PCM [i.e. uncompressed CD-quality] recording; MD's highest-quality mode is ATRAC SP [292kbps] which is of very good quality, though compressed nonetheless. Cheers. Quote Link to comment Share on other sites More sharing options...
