Sonic Stage 2.0 wont start
moormaster
Hi,
I have bought a Hi MD Player (MZ-NH700) and installed the software Sonic Stage 2.0.
Everytime I start the software it sais that the database has to be updated and then the program has to be restarted. When I click on OK it shows shortly a box with a statusbar and then the program just terminates without a message. If I restart it it tells me the same everytime.
I have tried to reinstall it for serveral times but the problem remains.
I hope anybody here can help me.
After a new install the message that one program is missing is not there anymore.
Since 2.1 i can start the database convert from the start menu. If I do that it says that the database cannot be converted because it is not new enough.
I wonder because i initialized a new one after deleting the old and still this message is displayed. Maybe there are some corrupt drivers for the database?
Somebody on one of these forums had a similar problem. If you do some trawling through the Technical Support, NetMD, and Hi-MD forums you might find a solution. I, personally, had a problem with a missing database engine component (a DLL), and SonicStage always complained about a corrupt database, that thread is buried in the forums somewhere also, I'm sorry I am really lazy.
The last thing I suggest is to uninstall all SonicStage and it's components and start all over. Read this faq here, incidentally this is the same one kurisu is pointing you towards.
I had installed SP2 for exactly 30 Minutes. After recognizing that my Graphics Card did only work in PCI Mode, my Internet Connection slowed down, my DVD Burner hasnt been detected, the IE asks on every popup if it should display it (what is even more annoying than just closing the popups) and that a lots of programs just didnt want to start i restored my SP1 Backup again.
I see no use in SP2 except that it makes everything more complicate since i would have to upgrade nearly every driver and every program on my pc. But for what? For a personal firewall and 300 new bugs?
The Depency walker points to one dll which takes longer to load. But this was only a function to ensure that internet is connected.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
MPR.dll
WNetRestoreConnectionA (has a red symbol in the PI column)
How can I see if one dll is older than the one which is required?
I found this out:
GetProcAddress(0x06D80000 [MIDIMAP.DLL], "midMessage") called from "WINMM.DLL" at address 0x76AF3C60 and returned NULL. Error: File Not Found (127)
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsAlloc") called from "METALLIC.DLL" at address 0x014E4742 and returned NULL. Error: Procedure not found(127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsGetValue") called from "METALLIC.DLL" at address 0x014E474F and returned NULL. Error: Procedure not found (127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsSetValue") called from "METALLIC.DLL" at address 0x014E475C and returned NULL. Error: Procedure not found (127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsFree") called from "METALLIC.DLL" at address 0x014E4769 and returned NULL. Error: Procedure not found (127).
