MDGB2 Posted November 30, 2004 Report Share Posted November 30, 2004 Hi, I want to install simpleburner on another PC at home and wondered if it is possible to import the file(s) that store the CD details that I have typed in the current installation, into a new installation. :wink: Is this possible and if so which files would I need to copy? Any help appreciated, Cheers. :grin: Quote Link to comment Share on other sites More sharing options...
Christopher Posted November 30, 2004 Report Share Posted November 30, 2004 You need to use the Sonicstage backup utility for this I believe..but I may be misunderstanding you. Are you referring to the track title and information? If so, then that should be automatically inserted by CDDB. Quote Link to comment Share on other sites More sharing options...
MDGB2 Posted December 1, 2004 Author Report Share Posted December 1, 2004 It is the track and title information that I want, but I haven't registered CDDB. I just type my track names in manually. Quote Link to comment Share on other sites More sharing options...
doclloyd Posted December 1, 2004 Report Share Posted December 1, 2004 I think there's just a Register button in Simpleburner. I've never (to my recollection) had to put in any personal info for it. I think the software takes care of it and I get CD info. The one thing I would like it to do is be able to pull in and transfer individual track/artist info. I have a number of compilation discs and so far it will use whatever the main artist name is for the disc and not pull in the artist listed on each track. SS does this just fine, however. Quote Link to comment Share on other sites More sharing options...
ksandbergfl Posted December 1, 2004 Report Share Posted December 1, 2004 Quote Hi, I want to install simpleburner on another PC at home and wondered if it is possible to import the file(s) that store the CD details that I have typed in the current installation, into a new installation. :wink: Is this possible and if so which files would I need to copy? Any help appreciated, Cheers. :grin:I'm not at home, so I can't verify -- but I believe that if you search in the directory where SimpleBurner is installed, you'll see a CDDB subfolder which will have the names/tracks of everything that's gone thru SimpleBurner to date. I would think you could just copy this to your new PC (after SimpleBurner was installed, of course). Take a look and see Quote Link to comment Share on other sites More sharing options...
