SonicStage doesn't work !
chanclo
I'm becoming mad with SonicStage !
I tried many times to install SonicStage 3.1 or 3.2. Each time, the result is the same : I can't use it.
My configuration : XP Home Edition Service Pack 2.
The last time, I proceeded like that :
I uninstalled all previous Sony software via the Add/Remove Porgrams control panel. I also deleted the references to Sony, OpenMG, Simple Burner and so on in the registry. I cleaned up the registry.
I installed MDAC.
Downloaded SS3.2 installer, run it. All is normal. Finally I obtain the following message : "Complete. SonicStage 3.2 has been successfully installed. You need to restart your computer before using SonicStage 3.2".
I reboot my PC, run SonicStage... and the messaage appears : "Before you can use the program, you must restart your computer".
Someone could help me please ?
