powermans Posted December 14, 2004 Report Share Posted December 14, 2004 Would appreciate any advice on a problem I am having downloading 2.3 Sonic Stage. I have 3/4 of the download completed however, I have the "ÄDD ON"stage plus set-up stage to go and as I get into 1.75MB of the "Add On "section the program stops and tells me that I have to check my internet connection or similiar. It always stops at the same point. Yet, the connection is fine and there appears to be no reason for the halt in downloading. Can any one assist??? Many Thanks, powermans Quote Link to comment Share on other sites More sharing options...
Christopher Posted December 14, 2004 Report Share Posted December 14, 2004 Welcome. What version of Sonicstage are you using currently? Quote Link to comment Share on other sites More sharing options...
powermans Posted December 14, 2004 Author Report Share Posted December 14, 2004 2.1 Sonic Stage came with the original purchase of the MZ-NH700. Have continued to try all avenues to download the last 2 sections of the 2.3 version but to NO SUCCESS! Quote Link to comment Share on other sites More sharing options...
Christopher Posted December 14, 2004 Report Share Posted December 14, 2004 2.2 is what I'd consider an upgrade worth your time, but it doesn't seem that 2.3 brought any huge improvements. If it works it works, don't screw with it. :happy: Quote Link to comment Share on other sites More sharing options...
