Has LP improved
Wundoo
A while ago I upgraded SonicStage from 1.5 to 2.1. Now I have noticed that the quality of LP4 recordings seems much better. There are almost no clicks and the 's' sound in vocals sounds cleaner and less fuzzy.
Does anyone know whether or not Sony change the encoding algorithms between versions of their software?
I find the high compression rates very acceptable for casual listening while walking around. It sounds better than FM radio. Half decent earphones make a huge difference though.
