Anyone ever hear of a sony ECM-MS909 mic?
justin_barbier
How are you planning to use it? It would be ideal for interviews where you could sit it on a table and point it at your subject, using the directionality to lessen background noise.
My (completely unfounded) guess is that it was an earlier version of Sony's ECM-MS907, though the 907 doesn't have as much bass response, only down to 100 Hz.
For similar specs at the same price you might want to look at this mic:
http://www.soundprofessionals.com/cgi-bin/...gold/item/ATR25
I don't know if that is a powered mic, though, which is useful for loud situations.
Sound Professionals also has an improved "knockoff" of Sony's ECM-MS907, but it'll cost you:
http://www.soundprofessionals.com/cgi-bin/...em/SP-ECM-MS907
