SS3.2, MP3 ,Atrac3, Convert, Transfer
Alexandr
Hello.
The problem: I have albums in MP3, I convert it with SS3.2 to Atrac3, but it showed in SS as MP3 and then I click the "transfer" button, files transfered as MP3.
I found, that in the property of this file in I see, it has 2 copies (MP3 and Atrac3). Only the way I found: in this property press "Delete" button on MP3 copy and then it appeared in SS32 as Atrac3 and it transfered als Atrac3.
This I should made for all files :ol_shocked: manualy. Is it possible to do it in auto mode?
Thank You.
I found this in knowledge base of Sony:
Knowledge Article C333142
How to delete song files that have been converted (optimized) to the OpenMG™ format in the SonicStage® 2.x software.
Follow this procedure to delete a file that has been converted to the OpenMG™ format in the SonicStage® software.
1. In the SonicStage window, click to select a track.
2. Right-click the track and select Properties from the menu.
3. In the Track Properties window, click the File Info tab.
4. Under File format, click to select the OpenMG file.
NOTE: To verify that the file is an optimized file, under Location, the file should be in the Optimized Files folder.
5. Click the Delete File button.
Is this possible made for multiple files automaticly?
