Sharp MT866 defect who can help???
stephan
Hi
I´ve buyed a used mt866. Now the problem is - if I layed horizontal the md it runs alltime ok, but if I moved in the verticaly or between it runs but the sound stops and the counter stands on the last time he played. I think its a problem with the mechanic between the disc and the player.
I´ve cleanded the lens and the frictionwheel with a q-tip and a drop of alcohol, but it doesn´t work.
Have anybody an idea??? :sad:
