Sepheriel Posted August 16, 2005 Report Share Posted August 16, 2005 OK. I have mp3 files on my comupter that I want to keep. I imported them into SS 3.2 and I converted them to ATRAC3plus 128 kbps. I want to transfer them onto my ATRAC device as the converted file without deleting the original mp3 file. I read Ishiyohi's post about something similar to this, but in my "convert to bit rate" pull down list, mine doesn't have the 128 kbps bit rate that I want to use. Please help me! Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted August 17, 2005 Report Share Posted August 17, 2005 Which ATRAC device do you employ? Please note that only a few ATRAC device such as the NW-E99 and the PSP can utilize all the new ATRAC3plus bit rates. If you use the NW-HD5, the only new ATRAC3plus bit rate you can use is the 192kbps. Quote Link to comment Share on other sites More sharing options...
Sepheriel Posted August 17, 2005 Author Report Share Posted August 17, 2005 Ishiyoshi said: Which ATRAC device do you employ? Please note that only a few ATRAC device such as the NW-E99 and the PSP can utilize all the new ATRAC3plus bit rates. If you use the NW-HD5, the only new ATRAC3plus bit rate you can use is the 192kbps.←I use the Network Walkman NW-E507 Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted August 17, 2005 Report Share Posted August 17, 2005 Sepheriel said: I use the Network Walkman NW-E507←In that case, you can only use the 192kbps. Quote Link to comment Share on other sites More sharing options...
Sepheriel Posted August 17, 2005 Author Report Share Posted August 17, 2005 Thanks for the help! Quote Link to comment Share on other sites More sharing options...
