Help-trying to uninstall all bundled software
Hautboise03
Hi,
I got a MZ-NH900 for xmas while visiting my parents out of state, and wanted to use it on the way home. So I uninstalled the previous software (my brother already has a MD, but used older software not compatible, SS 1.5) and installed software that came with my MD (all of this on my parents computer).
Then, I uninstalled the new software I just installed after I used it, because I was paranoid about the warning to have the software installed on only one computer (and I'm going to do that on MY computer when I get home, not my parents') and now my brother can re-install the software for his older MD player.
However, MD Simple Burner remains on the computer and I can't get rid of it. When I'm at Add or Remove programs and try to remove it, there is an error that says the specified module cannot be found.
Will this be a problem when my brother tries to install his software?
I think it would be helpful to have a list of all the programs that came on the CD and exactly how to uninstall them, especially the MD Simple Burner. Thanks so much! :grin:
