HandsomePete Posted January 4, 2005 Report Share Posted January 4, 2005 I'm thinking about getting a minidisc recorder to record my band practices. I'm currenlty borrowing someone else minidisc deck and like it. I have a mixer that i run into the deck and from the deck into my computer. I like this setup as i can record it to the computer for burning CD's and also use the computer speakers at the monitors. I now want to get my own and would like some advice. I can get the MDS-JE480 for $150 but like the portablity of something like the NH900. Do any of the portable models have a line0in and line-out so i can hook it up like the deck? thanks for the help. Quote Link to comment Share on other sites More sharing options...
aeriyn Posted January 7, 2005 Report Share Posted January 7, 2005 There are no Hi-MD decks.A portable Hi-MD device gives you more recording flexibility and ease of use (relatively speaking). You no longer have to re-dub recordings to the PC in real-time analog, but rather can transfer from MD -> PC via USB. Marcnet, one of the users here, has also devised an ATRAC-to-WAV converter that allows you to put your recordings on a universal medium (CDs).But above all, what is your maximum budget? Quote Link to comment Share on other sites More sharing options...
HandsomePete Posted January 7, 2005 Author Report Share Posted January 7, 2005 I'll spend up to $400. The cheaper the better but I want something that works and will last. I'm thinking the NH900 would be the way to go. Any other units you would suggest looking at? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
