aab Posted August 22, 2005 Report Share Posted August 22, 2005 I frequently record DJ live sets with my MZR4 MD recorder, so I have quite a library which I was thinking of loading onto an HD1 so I have less to bring around when I travel. At the end of each live set, I take the time to label each track on the MD, even if the music is non-stop (seamlessly mixed together). I transfer the data on the MD to my VAIO using SonicStage Mastering Studio, then take the time to label each track again so that I can locate the tracks when I burn the set on a CD.Recently, I thought of loading the music files to the HD1 with SonicStage 3.2, but was disappointed to discover that there are short one second gaps between each track so the music is not seamlessly mixed together anymore if playback is done on the HD1 (whereas there are no problems on MD or CD).Is there a simple solution? Am I doing something wrong during the transfer?I look forward to your feedback and tips.... Quote Link to comment Share on other sites More sharing options...
Ryzir Posted August 25, 2005 Report Share Posted August 25, 2005 The only way I have found to import gaplessly into SonicStage is through cd or image. I use nero to make an image and then mount it with Nero Image drive. Make sure that when you make an image there are no pauses between tracks and you are burning disc-at-once. Quote Link to comment Share on other sites More sharing options...
aab Posted September 6, 2005 Author Report Share Posted September 6, 2005 Thank you for the input. That seems to be the only solution that works. Quote Link to comment Share on other sites More sharing options...
