damianlhayes Posted January 8, 2005 Report Share Posted January 8, 2005 I only bought my MD MZ-NHF800 to play downloaded files on my HI-FI system. Previously i had to record through the microphone socket with poor results for considerable effort as each track needed a different analogue record level. Neither my YAMAHA MD deck or my JVC player support ATRAC3/plus playback, thus defeating the point of my purchase. How can I record NetMD using the older ATRAC format? or is my beloved MD deck now officially obsolete? Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 8, 2005 Report Share Posted January 8, 2005 Welcome..Switch the unit to NetMD mode. Refer to your manual for more information on this. Additionally, you can also select SP mode in Sonicstage, but I will note that it is not true SP, but LP2 rebadged as SP for compatibility purposes. The only way to get true SP is realtime recording in this situation.For some odd reason, Sony was never able to perfect SP transfers through NetMD. Quote Link to comment Share on other sites More sharing options...
damianlhayes Posted January 8, 2005 Author Report Share Posted January 8, 2005 Welcome..Switch the unit to NetMD mode. Refer to your manual for more information on this. Additionally, you can also select SP mode in Sonicstage, but I will note that it is not true SP, but LP2 rebadged as SP for compatibility purposes. The only way to get true SP is realtime recording in this situation.For some odd reason, Sony was never able to perfect SP transfers through NetMD.←Thanx it worked! Had to update to sonicstage 2.3 though, which decided to re-organise my database putting all 1050 tracks in the same album. Oh well {sigh}... Quote Link to comment Share on other sites More sharing options...
