How Can I Transfer Files From Cd To My Library As Mp3
KKop
I just got my NETMD (MZ-N420D) today, and have upgraded the Sonicstage software to version 2.3.
I am now transferring the files from my CD's to 'My Library'. I am trying to set the 'Format/Bit Rate' to MP3. According to the help, this should be possible, but it also mentions that:
'Note
"MP3 (MPEG1 Audio Layer 3)" cannot be selected unless "SonicStage MP3 Add-on Program" is installed on your computer.
Where do I get this add-on?
Thanks.
Rino
Even if you could get the app, I dunno about that, the N420D wouldn't be able to use MP3s. It only reads ATRAC3 files. LP2, LP4, and it can read SP files that were made via another recorder. The Sonicstage software can only convert MP3s to ATRAC3 files for your MD unit.
