My First Live Recording!
Tierce
Well I successfully managed to record the Brass line I teach with my MZNH-900 and Sony ECM-MS907 microphone. In general the recording was not bad, quality of sound was excellent.
BUT!!! Recording to Line produced a very quiet, at times inaudible sound and had a problem of the MD recording splitting a single recording between tracks.
If I used MIC, I would get generally good sound, but at the louder segments it would cut out which I believe is the pre amp overloading.
Therefore I am lead to believe I will have to use Line In recording for the quality but need to use a pre-amp so I can record the sound at a good level without any cut outs.
The problem being is this, after working this out I have trawled the net looking for pre-amps, unfortunately all the ones the look any good are in the US. I am looking for a good MD pre-amp which can be bought in the UK.
If anyone has any recommendations, and/or suppliers please let me know. Unfortunately I am in quite a tight budget.
Many thanks
Mike
You might try moving the mic farther away, and using the mic preamp with sensitivity set to low, and manual record levels.
Mic farther from subject = lower level from the mic; no preamp overloads from blasting horns. Though admittedly, I don't think you would be overloading that mic anyway.
Seriously, though. If that's it, then back off with the mic, problem solved. Why buy a preamp when you can spend $0 on moving the mic back half a metre.
Thanks for the reply, unfortunately I would have to knock holes in the wall to move it back being a small room.
I will need to do a bit of messing around with levels to see what works best.
The recording is incredibly clear apart from the clipping. I think the overloading is from the Mic on the MD player, so I am going to go for Line In recording from now on.
