From Computer To Md
Woogi
  Woogi said:
i have a home built amd 2600+ barton on a AU13 motherboard, my mobo has optical out on it, however when i try and rec to my MD player ( sony mds-s707 ) my MD rec. er tells me CAN NOT COPY. so my question is, is there any 3rd party software to fix that?
I'm not familar with that mainboard (it's a NF2 isn't it?). It might be that the Dolby Digital encoding is on, this would prevent you from recording from the optical SPDIF. The option is probably buried in the control panel applet that accompanies the audio drivers, I don't know exactly since I don't use my onboard audio.
