Sabaism Posted January 14, 2005 Report Share Posted January 14, 2005 (edited) The player/recorder I have is a MZ-N510, incase knowing that will help people here figure out what is wrong... or what I am doing wrong. Also I am doing this from a stereo to a MD, not a computer.I am obvisously doing something wrong or just not understanding it, here's the problem.My MD is set to record in LP4 Stereo mode and (with a 80 minute disc) get approx. 320 minutes. I am using a 74 minute disc and expect the amount of recording to be smaller, that isn't the problem.Using the player/recorder I can check the remaining time for recording and with a bank disc (74 Minutes) the remaining time reads 299:57. The disc I am trying to record onto has 14 tracks already on it. Nothing long like a Blue Oyster Cult song, just average songs. When I check the remaining time for this disc I get a time of 237:42. The Problem is when I got to add a track (4:57) the recorder stops before the song is done playing. Cutting it off in the middle. I've checked and double checked the connections, read and reread the manual to make sure everything is as it should be. I can't figure it out. Thus is must be a Loose nut behind the MD. Oh, when I put the problem disc into the player, without the MD starting to play, I get a time of 60:55. I assume that is the length of the material already recorded on the MD.Any ideas what's going on? It's either a disc or machine mulfuntion, or more likely I user error. Something I am missing and just not understanding.****EDIT****Forgot about this. Also when recording tracks they sometimes skip backwards a few seconds. Usually a re-recording them fixes the skip. There is one track that skips no matter what. Always this same track and always at the same spot. Now I have checked the source and there is no skip only when I record it. Edited January 14, 2005 by Sabaism Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 14, 2005 Report Share Posted January 14, 2005 Regardless, are you using Sonicstage 2.3? Quote Link to comment Share on other sites More sharing options...
Sabaism Posted January 14, 2005 Author Report Share Posted January 14, 2005 (edited) Also I am doing this from a stereo to a MD, not a computer.←No, I am not using SonicStage 2.3. Edited January 14, 2005 by Sabaism Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 15, 2005 Report Share Posted January 15, 2005 I apologize, I quickread. You should try the track via the computer nonetheless.. Quote Link to comment Share on other sites More sharing options...
Sabaism Posted January 15, 2005 Author Report Share Posted January 15, 2005 I apologize, I quickread. You should try the track via the computer nonetheless..←No Problem. Figure you read a lot of these all day bound to happen once and awhile.I don't have a computer anymore. The one I use to do this is in my apartment complexes office. I can't install anything. I would love to be able to use a computer to do this, be so much better. Quote Link to comment Share on other sites More sharing options...
Sabaism Posted January 15, 2005 Author Report Share Posted January 15, 2005 (edited) Damnit, did it to me again. First time I try to post it never shows, so I make a post again and then the first one shows up. Edited January 15, 2005 by Sabaism Quote Link to comment Share on other sites More sharing options...
