andrewhall Posted January 17, 2005 Report Share Posted January 17, 2005 I want to record some of my phone conversations. I know it sounds questionable but here's the story. I live in New Zealand and my mother lives almost exactly opposite me on the globe in Spain. She's 82. She's on her own. My father died a few years ago and my sister who lives in England has cut off from her. More and more I find myself appreciating her wonderful resilience and the way she handles her old age and her stories and her love for life. I want to capture some of it while I can. I've been thinking about this for ages but I need to get my act into gear and actually do it. I was thinking I could probably do something with my modem to make it act as a normal phone (I know you can also make internet based calls but that isn't a good option in this situation) and to route the telephone sound through the PC. But I haven't worked out how. Or maybe it is easier to find a phone that allows me plug in headphones and use a splitter to the HiMD (assuming there are such things). I imagine this is all very obvious to someone here - can anyone make a suggestion to point me in a sensible and workable direction.ThanksAndrew Quote Link to comment Share on other sites More sharing options...
LowMD Posted January 17, 2005 Report Share Posted January 17, 2005 If you just want to use the phone, go to a Radio Shack or whatever the local equivalent is for little electronics, and you probably have various choices: a simple suction-cup mic that sticks to the headset, a box that connects to your phone jack (you put a splitter on your phone jack so it has two connections), or possibly a phone with a headphone jack. The output may be mono, so you may have to get a plug that's mono-in and stereo-out, or you'll only be recording on one channel on the MD. Or try some software that popped up on Google and just record directly to PC: http://www.softpedia.com/get/Office-tools/...-Recorder.shtmlhttp://www.modemspy.com/en/index.php Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 17, 2005 Report Share Posted January 17, 2005 You need something like this. Quote Link to comment Share on other sites More sharing options...
andrewhall Posted January 17, 2005 Author Report Share Posted January 17, 2005 Thanks for the replies - that looks exactly what I need Kurisu I'll see if I can get one locally today. Really appreciate the helpAndrew Quote Link to comment Share on other sites More sharing options...
Bananatree Posted January 19, 2005 Report Share Posted January 19, 2005 Be sure you remember that it is a mono device, since phone is mono.So set your recording to Mono so you don't get stuck with one channel. Quote Link to comment Share on other sites More sharing options...
petertkalec Posted January 21, 2005 Report Share Posted January 21, 2005 No no, you'll get a stereo recording with both channels recording the same signal. It's a waste of space on your MD or HD, but you wouldn't get just the right or just the left channel. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted January 21, 2005 Report Share Posted January 21, 2005 I haven't paid really close attention to this thread, but as someone who's made telephone recording devices [it's basically just a transformer put on the line with DC and ring protection/filtering so the ring signal doesn't explode your recorder].. I'd seriously recommend NOT using any of the stick-on things, but going with those little boxes you just plug into the line. The quality is far better, not to mention more predictable. Quote Link to comment Share on other sites More sharing options...
