fredacho Posted January 21, 2005 Report Share Posted January 21, 2005 Hi there!I´m new in this forum. I´ve got a MZ N510, and I´d like to know if it´s possible to record, let´s say conferences using a microphone. Actually, with kind of microphone should I use, because the only possible input is an optical one (line in optical). Thanks a lot for your help. Quote Link to comment Share on other sites More sharing options...
A440 Posted January 25, 2005 Report Share Posted January 25, 2005 That is a line in OR optical jack, it takes either a minijack or an optical connector. But it is not a mic jack, which is connected to a preamplifier to boost the signal. The MZN510 doesn't have that built-in preamp. So to record via mic with the MZN510 you would need a mic plus a preamp. The cheapest preamps I've seen advertised, though I have not had any experience with them, are from Church Audio on eBay, around $60. Then you can add as good a mic as you need, from "Stereo Lapel Microphone for Minidisc" on Ebay (a cheap basic mic, OK for conversation) on through offerings from www.soundprofessionals.com , www.microphonemadness.com , www.reactivesounds.com , etc. For the price of a preamp, you could also find on eBay an old model MD, like the MZ-R700 or the MZ-N707, with a mic jack. But those will not do high-speed uploading to your computer--for that you need the new Hi-MDs. Quote Link to comment Share on other sites More sharing options...
