Colts Posted January 24, 2005 Report Share Posted January 24, 2005 HeyIm having this problem transferring songs onto my MD. Some songs work perfectly fine but others which is most of them has some trouble transferring. Some songs are stuck at 0% at the converting screen and some hit random stops like 28% and 54%. Im using a MZ-Nf610 and sonicstage vers. 2.3.If anyone can help plz it will be greatly appreciated.thx Quote Link to comment Share on other sites More sharing options...
Tiesto Posted January 25, 2005 Report Share Posted January 25, 2005 I will tell you about my experience with S.S.: If you have a mp3 file which doesnt transfer to the MD, you should check out the bit rate. If the file is VBR then code it to CBR.If you are transfering from a CD, check out if it has some scratches which may make the laser unable to read some parts of the song.If I am not wrong, I tried once to transfer a couple of song at Atrac3 105kbps to my NF610 but it wasnt able to play them back, I don't remember it well, maybe I will have to try it again... Quote Link to comment Share on other sites More sharing options...
