meycam1 Posted January 25, 2005 Report Share Posted January 25, 2005 Hi all, I am using sonic stage 2. something (seems to change once a month!) and am having a issue where I can not put more the the time printed on the disc says(say 74 Min). I used to be able to fit alot more but now with the new sonic stage I can't. Am I doing something wrong? or is it a sonic stage issue? Any help would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted January 25, 2005 Report Share Posted January 25, 2005 check your 'Format/BitRate' options at the bottom of the transfer screen. LP2 (Atrac 3 - 132/105kbps) or LP4 (Atrac3 66kbps) gives you a lot more time then the standard (and fake your SS) MDSP (which will give you the 74min only) Quote Link to comment Share on other sites More sharing options...
