I Need Md With Manual Rec-volume. Help?
henning
hi everyone.
I need a minidisc to which I can plug in my mic (i.e. the regular mic-input hole) and that I can manually change the rec-volume. a simple "high" or "low" rec-volume wont do it. Ive used tons of old MDs for recording sounds. Ive bought them all cheap and they've all broken down after a while... so I need a new one, but I havent found a new MD which will work for me. anyone know a new MD (one on the market now) that have those criteria?
hope someone can help...
/henning
  • 1 month later...
Look in the Browser tab on the front page of minidisc.org .
Any Sony MD since the MZ-N900 has manual volume control that you can set without pausing as you record. With the new Hi-MD's, unfortunately, Manual has to be specified each time you begin recording via the menu. The built-in default is AutoGain, and it returns to AutoGain each time you press Stop. But the NH-700, NHF-800, NH-900 and NH-1 all do allow manual recording.
