kpayson Posted January 28, 2005 Report Share Posted January 28, 2005 I am new to the MZ NH1 - have had an R50 for many years and want to do live recording int he pcm (uncompressed) mode.Everything seems to be fine - stereo out from mixer plays stereo on the headphones, but only the left channel gets a signal and records (live piano through mike into mixer stereo out into MZNH1) any thoughts? whatam I doing wrong??thanks Quote Link to comment Share on other sites More sharing options...
A440 Posted January 28, 2005 Report Share Posted January 28, 2005 Doublecheck that you're using a stereo plug connecting the mixer to the MD, with two circles (like the plug shown in my avatar), and not a mono plug, with one. Quote Link to comment Share on other sites More sharing options...
kpayson Posted January 28, 2005 Author Report Share Posted January 28, 2005 Doublecheck that you're using a stereo plug connecting the mixer to the MD, with two circles (like the plug shown in my avatar), and not a mono plug, with one.←Thanks - all the plugs are stereo - (two rings) - it was already nearly 3AM so now fresh from 4 hours of sleep and the kids off to school and the dogs walked I can now try this again - I'll see if it sends stereo signal into my old R-50. Quote Link to comment Share on other sites More sharing options...
kpayson Posted January 29, 2005 Author Report Share Posted January 29, 2005 OK - I just got a new cord and it was the connections not the settings - all is well and I LOVE pcm recording - the piano sounds incredible.Now I only need to use my MDM X4 for it's inputs/outputs and mixing - I will try one of those xlr to minijak cables you have suggested for portable recordings.Thanks Quote Link to comment Share on other sites More sharing options...
