lardless Posted January 28, 2005 Report Share Posted January 28, 2005 I bought a backlit remote (the MC11EL) for my NH700 Hi-MD player. I plugged it in, everything was fine for a couple of minutes until the sound only came out of the right earphone. It works fine with no remote or the remote provided with the unit, so am I right in assuming that this is some sort of voltage problem, presumably to do with the backlight, or is there a fix?Thank you! Quote Link to comment Share on other sites More sharing options...
RichM Posted January 28, 2005 Report Share Posted January 28, 2005 lardless said: I bought a backlit remote (the MC11EL) for my NH700 Hi-MD player. I plugged it in, everything was fine for a couple of minutes until the sound only came out of the right earphone. It works fine with no remote or the remote provided with the unit, so am I right in assuming that this is some sort of voltage problem, presumably to do with the backlight, or is there a fix?Thank you!←I've never heard of this before, but it does sound like the remote control. However the MC11EL was never designed for that unit, it was originally supplied with the R900 back in 2000. Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted January 28, 2005 Report Share Posted January 28, 2005 In either case, unless the MC11EL and R900 use a 4-conductor audio connection, there is no reason why it shouldn't be workig with any pair of 'phones.It's possible that the remote connector is too long, preventing the 'phone connector from fully inserting. Quote Link to comment Share on other sites More sharing options...
lardless Posted January 28, 2005 Author Report Share Posted January 28, 2005 Many thanks for your replies. I'll take the answer to be a 'no', then. Could you recommend me a brand of remote which is guaranteed to work? Quote Link to comment Share on other sites More sharing options...
