Recording Mds
jesssales
Guest NRen2k5
Your recorder is recording in "SP" mode. If it is "MDLP-compatible" (recorders before the year 2000 are not) then you can record in LP2 or LP4 format. LP2 will let you fit 2 CD's on 1 MD with reasonable sound quality. LP4 will let you fit 4 albums on 1 CD but it will not sound as good.
You could also try reading your user guide that came with your unit. That's always the best place to start. The Sony ones are fairly informative, and provided great info on how to get started recording, especially for those new to MD.
After that, the FAQ section @ http://www.minidisc.org is the best place to go for all your info.
If you've lost your guide, or you didn't get one with your unit, most of them can be found online.
