Mds-je480 Not Ripe For Modification.
Cheese
I recently purchased one of the 480 decks, thinking it would be almost exactly the same as the 470. Not to be! the main board is quite different and has no mounting points for optical out or the other usefulconnections the previous model had. Looks quite cheap inside.
I can provide photographic evidence if you don't believe me.
Perhaps the lack of optical out mod ability should be on its page in the browser, so its vices catch out fewer would-be buyers who assume it's basically the same as the 470, or any previous deck in the low range.
If anyone has done or can do a optical out mod for this deck, let me know how it's done.
It will be a much greater challenge compared to previous decks.
Otherwise it seems pretty good, for what it is.
