Chris Kelly Posted February 9, 2005 Report Share Posted February 9, 2005 Hi folks,Im going to buy a Net MD, for the USB->PC transfer functionality, but no matter what website I go to I can't find out which Net MD's will allow me to plug in a mic via 3.5 jack and record on to MD.I know older MD players with a "record" are more expensive. Is this the case with Net MD or are the no Net MD's that have record from a mic function because they are solely PC->MD via USB?Needing a little help before a purchase,New Board Member from UK,Chris. Quote Link to comment Share on other sites More sharing options...
zerodB Posted February 9, 2005 Report Share Posted February 9, 2005 (edited) The minidisc equipment browser is your friend!!!Try looking here: http://www.minidisc.org/equipment_browser.htmlIn terms of the latest NetMD units:MZ-NE410, N420D, NE810 - MD Downloaders only. No audio input jacks.MZN510 - Basic NetMD unit with 3.5 line-in/optical jack. (used to record analog powered sources such as stereos, tape decks, etc.)NF610 - Same as the 510 but with a radio tuner remote.N710 - More advanced NetMD unit with 3.5 line-in/optical in AND MIC-IN for recording from stereo MICSNF810 - Same as N710, but with radio tuner remote.N10, N910, N920 - Top of the line NetMD models. All have MIC in/line in/optical in. The N10 is the smallest of the bunch, owing to its built-in battery. The N920 and 910 have gumstick batteries. The 920 has a digital amplifer to reduce battery consumption.My recommendation is to either get a 910, 710, or used N707 in good condition on ebay. Edited February 9, 2005 by zerodB Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted February 9, 2005 Report Share Posted February 9, 2005 Im going to buy a Net MD, for the USB->PC transfer functionality, but no matter what website I go to I can't find out which Net MD's will allow me to plug in a mic via 3.5 jack and record on to MD.I know older MD players with a "record" are more expensive. Is this the case with Net MD or are the no Net MD's that have record from a mic function because they are solely PC->MD via USB?←Most importantly: there are no netMDs that allow MD->PC uploading. HiMD allows this, but netMD does not. There is currently no way to transfer recordings from a legacy MD/LP disc [i.e. original MD, MDLP, and including netMD] to a computer other than by analogue means or using the optical output of a home/pro component deck. You can upload using HiMD, but only with HiMD-formatted discs. Quote Link to comment Share on other sites More sharing options...
Chris Kelly Posted February 10, 2005 Author Report Share Posted February 10, 2005 Most importantly: there are no netMDs that allow MD->PC uploading. HiMD allows this, but netMD does not. There is currently no way to transfer recordings from a legacy MD/LP disc [i.e. original MD, MDLP, and including netMD] to a computer other than by analogue means or using the optical output of a home/pro component deck. You can upload using HiMD, but only with HiMD-formatted discs.←Ahh thanks. Very imporant piece of info that. I'll use anologue recording then via 3.5 to 3.5 stereo jack into the line in on my sound blaster live then. I've got a registered recording prog.Thanx Dex.Chris Quote Link to comment Share on other sites More sharing options...
RookieTaper Posted March 7, 2005 Report Share Posted March 7, 2005 Is there a way to get a microphone to work with a line in?I have an MZ-S1 that has a line in/optical jack. And If I plug a mic into it and record, I get a faint sound. Probably in the -50 to -20 decibel range (guessing)What are my alternatives to buying a different model?Thank anyone for their help! Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted March 8, 2005 Report Share Posted March 8, 2005 You need a microphone pre-amp for recording normal everyday level sounds, or a battery box (battery module) for recording sustained high level sounds (like at rock concerts), or an amplified microphone.These will allow you to record through a line in. Check sites like soundprofessionals.com. Quote Link to comment Share on other sites More sharing options...
RookieTaper Posted March 8, 2005 Report Share Posted March 8, 2005 (edited) You rock dude. Thanks alot. Edited March 8, 2005 by RookieTaper Quote Link to comment Share on other sites More sharing options...
