johnyg Posted February 9, 2005 Report Share Posted February 9, 2005 I'm new to minidisc and was wondering if it is possible to connect my sony himd nh700 to my hifi and use it to play back through the hifi.I know i can record to the minidisc but slightly confussed if it can play back the other way.Hifi is a yamaha crxe300 with opitcal and audio pin connectors.Thanks. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted February 9, 2005 Report Share Posted February 9, 2005 yep i do this at my house. you need a stereo mini (male) to stereo (left right chanel) cable. Plug the stereo mini cable into your headphone jack and the left right channels into their audio inputs. Blast the HiMD at 30vol (if possible) and then control the audio with the amp itself Quote Link to comment Share on other sites More sharing options...
Guest NRen2k5 Posted February 9, 2005 Report Share Posted February 9, 2005 Actually the name for this is a "3.5mm to RCA Y-plug". Specifically, you want one that is male at both ends. Quote Link to comment Share on other sites More sharing options...
johnyg Posted February 10, 2005 Author Report Share Posted February 10, 2005 Sweet, i’ll be getting one of those leads tomorrow.It will be so good to have my md loaded with music without having to resort to pesky cd changing.So the optical out can only be used for transferring from cd – md but there are connections for audio inputs from md , tape and aux to play with. Bought the Yamaha mini hifi today from http://www.unbeatable.co.uk/CatalogueItem_20422.html for £139.98 and the sound acoustics are breathtaking for the price. Graded product so the boxes have been opened but what the heck when it retailed last year at £299.00.I’m very happy with my purchase. Quote Link to comment Share on other sites More sharing options...
ROMBUSTERS Posted February 10, 2005 Report Share Posted February 10, 2005 Actually the name for this is a "3.5mm to RCA Y-plug". Specifically, you want one that is male at both ends.←ya i can never remember the name.oddly enough my HiMD came with one (havnt heard of anyone else having the same luck).MZ-NH700Ontario, CanadaCame with SonicStage 2.1 Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted February 10, 2005 Report Share Posted February 10, 2005 Additional advice for hooking up your portable to your stereo amp:* turn off AVLS* turn off EQ [see below]* set the output volume to 25/30The EQ .. HiMDs without the digital amp [NH600, NH700, NHF800] have a slight rise in bass response that will likely be exaggerated when plugging into an amp. It is advisable to either turn the EQ off completely or else to use one of the custom settings with an all-flat setting except the very bottom [actually, the leftmost] band; turn this one down one or two notches to compensate for the bass boost. Quote Link to comment Share on other sites More sharing options...
