Mz-nh700: Trouble
Taka
I bought the MZ-NH700 to be able to record my band while practizing. I don't want to use it to download music or copy my music CD's or whatever.
Now the device I bought came with a 1GB minidisc, which i can't seem to get working properly.
* I tried to record some stuff. After the first time it started to give an REC ERROR every time i recorded something new.
* It recorded something apperently, because there's 3 MB file on the disc which i can see in Windows explorer after connection it through USB. Also I once succeeded in playing it in SonicStage (I have version 2.1), but I can not repeat it.
* I tried transferring that recording in SonicStage to apperently my HD. But that did not work, although there was no error.
Anyway, it was just testing, and i don't care very much if the recording is lost.
So I tried to use SonicStage to "initialize" the disk. On several tries several things happened:
- first try was not succesfull, i got an error message from the program saying - i don't recall the exact wording - that it was unable to initliaze the disc.
- second time it asked me if i wanted to transfer the recording first, and i said "yes". It did some things (but no sign of a transferred file). Then it returned to the "initialize" option screen and froze.
- Since then the whole program crashes whenever i start it. At startup, the MD-player starts spinning, displays "ACCESS" and then "ACCESS ERROR", and then the program just crashes.
Ok i was not particularly happy with my new device in the first place, because
* At first it could not transfer recording from older (non Hi-MD) minidiscs through USB - and that was an important thing to me.
* Then while browsing i found out that a lot of Sony sites force you to use Internet Explorer, and do not accept another browser. For no obvious reason.
* Sites do not have a contact email address to send questions to. It's true that i found some chat-support, where a very polite "Bob" was trying to explain things, but then again, he could as well have been a bot, his answers were very standard and emotionless. And it did not help me.
* I read about a newer version of SonicStage (version 2.3), and wanted to download it. Places i get are Internet Explorer-only and meant to download music. And as said I don't want to download any music.
Sony seems to be a lot worse then Microsoft in being unreachable and just doing everything to make you pay, but not offering any service. Yes, it makes me angry.
Anyway: can anyone give me a clue on solving the issiues mentioned:
1. I want to be able to record stuff from a microphone. Why does everything seem to work untill the "REC ERROR". Is my disc corrupt?
2. I want to be able to "initialize" the disc (if nothing else). I guess that it is something like formatting. Why doesn't that work?
3. I want to download the latest version of SonicStage without doing any payments for music (because i don't want to download music)
4. I want to spit in the face of Sony for being so very consumer-unfriendly and apparently only being busy with making people pay.
Taka
Just to add something:
I know why i was not able to find the latest SonicStage version after going to the indicated page at http://musicstore.connect.com/mb_us/IESignup.flow
1. It's a confusing page. It says "download Connect Player", while i was looking for "SonicStage".
2. The download does not work in Firefox (or rather: does not work with a popup blocker).
When do people learn that popups are passé?
And why does the the MP3-library program not ask me where i want it installed?? It just installs on C:\Program Files
That is NOT where i want my programs to be installed.
When does the annoyance ever stop?
I already found and installed it.
I get "ACCESS ERROR" on the display of the MD-player all the time. Even after running Windows checkdisc. Windows reported to have found errors and fixed them. But I still get an error when working from Window explorer, and trying to copy some of the files there. I can write a file, and then read it again, but I can't copy at least some of the files currently present on the disc.
the files i can see are:
Hi-md.ind
a directory named "Hmdhifi" with these files:
_0010012.hma
_mdhifi.hma
00010012.htm
atdata02.hma
mclist01.hma
mclist02.hma
trkidx01.hma
trkidx02.hma
Using SonicStage:
On "transfer" the first time it starts transferring untill 65%, and then meets an error and stops transferring. After that nothing has been transferred. After that SonicStage does not see any recordings anymore.
"Initialize" fails.
What should I do? Format the disc from Windows and then try "initialize"? Or is that something to never do.
I have reformatted the disc from the menu in the player, and now it seems to work as it should.
Any clue as to what went wrong? How can one corrupt a disc in such a way that it refuses to function?
Now that I think about it. I might have interrupted the proces of writing to file after the first recording. It seemed to be taking a lot of time, and i needed to start recording the next song. Could that have corrupted the whole disc, not just the file?
Anyway this problem seems solved, thanks. Now for the next problems - I'll start another thread about those.
