nite Posted February 13, 2005 Report Share Posted February 13, 2005 hi, I upgraded to SonicStage 2.to use the Wav conversion tool: when I open the tool, the library is empty. I assume this is as the default location of the library has changed. Is there any way to force it to check another directory? It's on a mate machine, so havent had a chance to try moving the folder back to the original location. What is the default library folder by the way? cheers, andy Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 15, 2005 Report Share Posted February 15, 2005 Try using Marcnet's Hi-MD renderer. Much better at locating files, regardless of directory. Quote Link to comment Share on other sites More sharing options...
nite Posted February 16, 2005 Author Report Share Posted February 16, 2005 Try using Marcnet's Hi-MD renderer. Much better at locating files, regardless of directory.←Cause I've never heard of it! for everyone's info, here's the linkhttp://www.marcnetsystem.co.uk/Anyone got any ideas on my mp3 distortion problem on the other thread? Read right to the bottom .... Cheers kurisu, AC Quote Link to comment Share on other sites More sharing options...
nite Posted February 16, 2005 Author Report Share Posted February 16, 2005 Try using Marcnet's Hi-MD renderer. Much better at locating files, regardless of directory.←sofar it has rendered out 2 0k files and crashed twice! any other ideas people??cheers, andy Quote Link to comment Share on other sites More sharing options...
StEaLtH Posted February 16, 2005 Report Share Posted February 16, 2005 Here is solution. You have to import you files (that was recorded from analog source) in SS. Then lunch Wave Converter and select in dropdown menu, something like - ** all ****** or last. Then list of files? ready to conversion is appears. Good luck Quote Link to comment Share on other sites More sharing options...
zerodB Posted February 19, 2005 Report Share Posted February 19, 2005 I upgraded to SonicStage 2.to use the Wav conversion tool: when I open the tool, the library is empty. I assume this is as the default location of the library has changed.←Note that the WAV conversion tool will only display media that has been uploaded from Hi-MD to PC, and recorded from an analog connection (not digital). Quote Link to comment Share on other sites More sharing options...
lynnemc Posted February 27, 2005 Report Share Posted February 27, 2005 Hi there - I am also having a problem with the library in the WAV conversion tool being empty, and the previous posts don't solve it, alas. Choosing "all convertible tracks" on the display mode does not display any files. An online-tutorial indicated that I should also be able to choose "Recorded on HiMD" (or something like that - I can't remember exactly) from the display mode, but that doesn't appear.The recordings I am attempting to convert were recorded live on an MZ-NH1 through the Mic input, so they should be convertible, yes? They were originally transferred from the MZ-NH1 to SonicStage 2.0. Then I upgraded to SonicStage 2.3 (the files transferred to the 2.3 version okay, as far as I can tell). Then I downloaded the WAV conversion tool, but it isn't picking up the files from the SonicStage library.Can anyone help?I want to burn these files to CD but it has been an incredibly frustrating trip!! Reading the posts here has been extremely helpful - thanks so much for all the info. I was so glad to find out I wasn't the only one cursing Sony. Quote Link to comment Share on other sites More sharing options...
Christopher Posted February 28, 2005 Report Share Posted February 28, 2005 Try Marcnet's utility. Quote Link to comment Share on other sites More sharing options...
lynnemc Posted February 28, 2005 Report Share Posted February 28, 2005 Try Marcnet's utility.←I just did, and it worked, so kudos to him and I'll be tripping over there to make a donation.Still, I'd like to see if I can get the sony wav converter to work...if only to hold their asses to some accountability. It should work!!I know, I know.....it's a fool's errand.... Quote Link to comment Share on other sites More sharing options...
