as you probably know, RealAudio 8 is based on ATRAC3. With Helix Producer 9.2 it is possible to create ATRAC3 audio files with bitrates ranging from 66 to 352kbps.
If you want to test it (for whatever reason), you can grab Helix Producer 9.2 here (registration required):
DaNnY_
Hi friends,
https://helixcommunity.org/account/login.ph...a%2Fdownload%2F
I have already done some testing on the CLI, written a RPAD config-file and trancoded a WAV PCM to ATRAC3 @ 352kbps.
Command-Line:
test.rpad:codecFlavor 0 = 66kbps (LP4)
codecFlavor 1 = 94kbps
codecFlavor 2 = 105kbps (LP2)
codecFlavor 3 = 132kbps (LP2)
codecFlavor 4 = 146kbps
codecFlavor 5 = 176kbps
codecFlavor 6 = 264kbps
codecFlavor 7 = 352kbps
With this information you do not have to read through the docs anymore. So feel free to use it...
Unfortunately, container format is RM, of course...
FYI RealAudio 10 is already based on HE-AAC.
