Problem With Near End Of 80min Disc
Guest tony wong
Guest tony wong
did anyone also find this problem?
I found my E710 usually can't play songs at that sector
it either stop at the middle or just can't access song near the end
oh my god, I just bought another 10 of these 80min disc....
thought I can use them to record 2 cd both of around 40 mins, that a 74min can't do it
is it a common problem when portable player encounter when facing a 80min MD disc?
is it the disc problem or player problem?
I did try it on my mini system(cmt-n333nt), reading ok at that sector no problem
[added at later times...]
I know it seems a known problem, I just want to clarify it
coz I really can't remember if it's really true
(read about it some times ago in here or other place on internet)
Edited by tony wong
Guest tony wong
Do these discs play without problems in
your bookshelf system?
If yes, try cleaning the lens of the E710.
1. yes, no problem
2. did
but I just found out that TDK lens cleaner is just a very little brush standing on the disc......
